Jordis 1988 Samurai (Re)Build
- dazerede
Yr true
I was thinking of doing my alloys aswell what prep and primer did u use as u seem to have done a good job.on them
4” calmini lift kit
4” calmini lift kit
Various copper wire brush drill attachments to get the thick corrosion and loose paint off.dazerede wrote:Yr true
Then roughed the whole wheel up with 100grit production paper. Smoothed it off with 400grit production paper.
Pretty much washed the wheel down with cellulose thinners to remove dust and any traces of grease.
I used bog standard simoniz white primer in a rattle can and carplan satin black top coat. To get the paint to adhere and dry better I sat the wheel over a convector heater till it was warm to touch then sprayed it with as many coats of each as you can be bothered (I did 3 coats of each)
There not perfect up close but I'm pleased with them, one of the small jobs that makes a big difference.
Also been out and collected an 8x4 sheet of steel
- dazerede
Ideal chears jordi as my alloys look sh*t in silver
4” calmini lift kit
4” calmini lift kit
why do you mask them wheels? just get a piece of cardboard, and cut an arch in one side. then just bend it a little to make it fit perfect around your wheel, and just hold it where you are spraying, and work around. one piece of cardboard for all wheels, and just keep it somewhere, and use it again next time
works a treat man
works a treat man
Saves any potential slips, plus I had all the masking stuff to hand.kiwizook wrote:why do you mask them wheels? just get a piece of cardboard, and cut an arch in one side. then just bend it a little to make it fit perfect around your wheel, and just hold it where you are spraying, and work around. one piece of cardboard for all wheels, and just keep it somewhere, and use it again next time
works a treat man
Bungs out!
Keeps it nice and airy to stop moisture build up in the cab, stops the floor rotting, let's the crap out after a deep wade.
I ain't had any of my front or rear ones in for a few years now.
- dazerede
I keep my rear ones in but I might just keep 1 in.each footwell tbh
4” calmini lift kit
4” calmini lift kit
Put them back in for wet weather road driving, or do as I do - throw a cheap rubber mat over them.
You don't want motorway road spray coming up into the cab and freezing your manberries off.
Well, I don't - I have no idea what you do for fun...
Its also funny to get your passenger's feet wetJordi wrote:See, Robbie knows the crack.ROBBIE wrote:If you leave the bungs out the river water washes the mud out
Started doing a bit of the gentle cosmetic work to tidy up a bit more.
Err.... We have the rot. The seams in the floor behind the seats have gone. Fairly sure the mud is holding it together.
Think it's gonna be pay n play this weekend then the body off. To say I'm gutted doesn't describe it.
