Engine Rebuild Parts
AndyD
Post by AndyD » Wed Apr 02, 2014 1:26 pm
Has anyone on here done a full engine rebuild?
I currently have a 1.6 (G16A) in pieces ready to rebuild, but my local garage (run by a friend of mine) is struggling to find the parts I'm after. All they can definitely get so far is the full gasket set, timing belt and accessory belts.
But I'm also in need of;
Main Bearing Shells
Thrust Bearings
Big-End Bearing Shells
Piston Rings
Anyone obtained these before?...
dominic
Re: Engine Rebuild Parts
Post by dominic » Wed Apr 02, 2014 9:23 pm
Hi Andy,
I have done a full engine rebuild, but only on a F10A engine. that was 10 years ago.
I have no idea about the G16A engine.
I cant help you matey, sorry , but im sure someone here can.
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Post by ScottieJ » Wed Apr 02, 2014 9:36 pm
AndyD
Post by AndyD » Thu Apr 03, 2014 1:14 pm
Cheers Scottie! I'll give them an e-mail...
Post by mike harris » Thu Apr 03, 2014 8:45 pm
I've got a calmini rebuild kit I'd sell for the right money? :)
AndyD
Post by AndyD » Sat Apr 05, 2014 5:52 pm
Thanks for the offer mike, how much is the right amount? Though I wouldn't need the pistons and pins if it's the full kit you have.
This is the reply I got from Kar Engines;
Hi Andy,
Thank you very much for your enquiry regarding the engine parts you require for the G16A.
Prices as off below;
HEAD SET UDS601 £28.50
CONVERSION SET (BOTTOM END) £18.00
TIMING BELT UTB4170 (NO KIT AVAILABLE NOW) DAYCO BRAND £12.50
BIG END BEARINGS £28.50 (ENGINE SET) CR4056
MAIN BEARINGS £44.00 (ENGINE SET) MB5587
THRUST WASHERS £8.00 (ENGINE SET) TW144
PISTON RINGS CHOICE OF LAYOUT £65.00
The head set, conversion set and timing belt are available ext stock but the other items I can get for you are special order and non returnable.
All prices are plus vat and carriage charge of £6.50.
Best Regards Darren
Kar Engines
So it seems they can get me what I need at £252 total.
Could you better that mike?
And might it matter the size of parts you have?
According to Haynes I need the main bearings in Std Sizes; 2x Yellow, 3x Colourless, big ends and piston rings would be Std size.
Post by ScottieJ » Sat Apr 05, 2014 6:47 pm
Glad they could help matey! And thanks for posting up the prices that's really handy as I have a few 1.6 8vs that could do with a rebuild!
Post by mike harris » Tue Apr 08, 2014 12:00 pm
Il speak to Paul :)
Post by mike harris » Tue Apr 08, 2014 12:08 pm
Andy,
£200 mate
Pistons, rings, big ends, mains, rings, and performance long duration cam
And head gasket.
dazerede
Post by dazerede » Tue Apr 08, 2014 6:57 pm
I'm also rebuilding a g16 8v engine but only dong head gasket water pump and a few other goodies won't be doing piston rings or that sort of stuff
4” calmini lift kit :)
