How do you get the oil in the diffs?
themac
Post by themac » Fri Nov 21, 2014 10:51 am
I am following the guide on this site on how to change the oil in the diffs and I am stuck on the front axle. The fill-plug is as stuck as they come so I'm trying to get the oil into one of the bolt-holes who holds the diff-housing to the axle. Is it possible to do without having to remove the axle?
The hole is so tiny.
1986 Suzuki SJ413JX
1987 Suzuki Swift GLX
1973 SAAB Sonett Mk3
1996 SAAB 9000 2.3 Turbo
1975 Puch Dakota 70cc aka. The Angry Wasp
2007 Deutz-Fahr Tractor, my comfiest ride
Ladaman
Re: How do you get the oil in the diffs?
Post by Ladaman » Fri Nov 21, 2014 11:26 am
Those holes will allow oil into the diff, eventually, but it will be a very slow job as you rightly say.
A slightly extreme way of slackening is with a chisel.
:shock:
courior
Post by courior » Fri Nov 21, 2014 11:40 am
You could pop off the breather cap and pour it in that way :)
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Ladaman
Post by Ladaman » Fri Nov 21, 2014 12:46 pm
courior wrote:You could pop off the breather cap and pour it in that way :)
Ooh yeah, I add a bit extra through there on mine.
themac
Post by themac » Fri Nov 21, 2014 1:53 pm
Got it done :) It's sub zero degrees out and I was laying in the semi-frozen mud holding a hose and the girlfriend was pouring. She is NOT happy atm. Well, well :D
1986 Suzuki SJ413JX
Post by ScottieJ » Fri Nov 21, 2014 2:32 pm
Get a nice long breaker bar on the film plug, should soon come undone
themac
Post by themac » Fri Nov 21, 2014 3:44 pm
Thanks for all your help, Ill be on with the transmission tomorrow, so more noobish questions then! Now a pint and some bullbar-designing.
1986 Suzuki SJ413JX
Post by Anton » Fri Nov 21, 2014 5:24 pm
I put oil in mine through the correct hole, and that's difficult enough. Ended up getting loads of it on my jacket, which even after going through the washing machine 4 times, still stank too much of gear oil to wear.
God I hate that smell.
Next time I'm going to pour it in through the diff breather until it comes out of the fill hole.
shredder
Post by shredder » Fri Nov 21, 2014 5:59 pm
washing up liquid bottle and a length of hose
Post by donkeychomp » Fri Nov 21, 2014 9:43 pm
You can use a massive syringe, a mate has one.
