Advice after fitting 2/3" lift springs
- Josh-holden
Iv just fitted 2/3" lift springs and when the truck is sat on the floor the shackles are nearly vertical and at different angles either side? Is this ok or is it a problem?
- With lift springs fitted
- image.jpg (969.29 KiB) Viewed 9239 times
- Josh-holden
Re: Advice after fitting 2/3" lift springs
Before lift springs
- image.jpg (854.96 KiB) Viewed 9238 times
The springs look a bit short... Do you know what type they are? Where did you get them? Will.probably be an uncomfortable ride like that
Did you get them from matt in the end?
- Josh-holden
Yes I got them from matt, I don't know what type they are or what they are from
They are made by smj. They are a good few years old
And been on a couple of trucks to my knowledge so
A well made spring.
I never tried them on the road but id imagen they could
Be quite a stiff spring.
A well made spring.
- Josh-holden
Ok. Is this a common thing to happen with the shackles? Do any of you guys know what shocks that i could use now?
When the spring flattens under articulation, the shackle will go back to where it was before. That shackle looks like it's in roughly the right place for a 3" lift spring to my relatively untrained eye.
- Josh-holden
Ok I'll see how it goes. Need to find some shocks first though
- Josh-holden
Also Is their anything I need to change steering wise?
