Telling the difference between Jap calipers and spanish
Hey guys im looking to buy a set of calipers off one of the guys on here but we are unsure if they are Jap or Spanish, is there anyway to tell the difference. I have a Spanish sj410 and they are for the disc conversion.
if the calipers are different can i still use the discs and the caliper mounts?
Re: Telling the difference between Jap calipers and spanish
Jap ones should say asin on them and have littlw clipsgamble63 wrote:Hey guys im looking to buy a set of calipers off one of the guys on here but we are unsure if they are Jap or Spanish, is there anyway to tell the difference. I have a Spanish sj410 and they are for the disc conversion.
Either sides of the pads.
Spanish should say lucas and have a squarer pad with
Springs on the top of them.
Jap SJ's tend to have Aisin calipers:
Spanish SJ's have Lucas-Girling:
That's the best picture of a Lucas-Girling I have, although it's a Vitara one and so the bleed valve and the bit where the brake line bolts in are in the wrong places.
Should (I think) still look a bit like that.
So could i not use the discs and caliper mounts off a Jap model with spanish calipers?
Discs are fine . Caliper mounts should be differentgamble63 wrote:So could i not use the discs and caliper mounts off a Jap model with spanish calipers?
Shit! lol not looking good so far unless i run Spanish at the front and Jap at the back but that is just annoying lol
I always assumed the mounts were the same, but I've never been near a Lucas-Girling caliper.andyrew wrote:Discs are fine . Caliper mounts should be different
I know Vitara calipers fit SJ Aisin caliper mounts, I guess I assumed that the same would be true of Lucas-Girling SJ calipers.
Gamble63 - what existing calipers do you have?
I have at the mo Spanish ones i believe as the car is a Spanish one.
the chap who said he could sort me out the dics, calipers and mounts has ones off a Jap model and a set of girling calipers.
id rather only carry one set of pads if i need to.
- kibris
The mounts are the same - I ended up running with Aisin at the front and Girling at the back when I did my Fully floater as thats all I could get at the time.
Ah good news
thanks for that shall try and source the same and if not run different as a last resort. Are the girling ones Spanish ?
Cheers guys
Cheers guys
