electric fuel pumps
electric fuel pumps
Post by andyrew » Thu Apr 02, 2015 10:01 pm
Hey dudes
I've got to purchase an electric pump to feed the weber
For the vit conversion. Can anyone recommend
A brand they've had good experience with?
Any too avoid?
Re: electric fuel pumps
Post by dan_2k_uk » Thu Apr 02, 2015 10:03 pm
I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
Post by ScottieJ » Thu Apr 02, 2015 10:28 pm
dan_2k_uk wrote:I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
It is solid mounted and right behind the driver seat in the back :lol: that doesn't help! Need to get some isolated rubber mounts for it, that will quieten it down.
daemon982
Post by daemon982 » Fri Apr 03, 2015 5:06 am
This is what i use to feed vitara carb, it works great. You don't even hear it. I have it mounted in engine bay.
http://www.kraftstoffpumpen.com/benzinp ... -c-25.html
kibris
Post by kibris » Fri Apr 03, 2015 11:10 am
I use one of these
Click Here for Ebay Listing
designed to suck so can be mounted under bonnet - works well - lot quieter than the facet.
Post by Jordi » Fri Apr 03, 2015 3:30 pm
I've got a facet pump Andy. Now mounted on a rubber bush.
Post by andyrew » Fri Apr 03, 2015 6:58 pm
im guesing the fuel return just gets blanked off?
Post by Jordi » Fri Apr 03, 2015 8:43 pm
andyrew wrote:im guesing the fuel return just gets blanked off?
There won't be a fuel return. The webber doesn't have one, just fuel in. The fuel return is off the pump on the propper carb'd 1.3 and 1.6s.
Post by twiss » Sat Apr 04, 2015 5:59 am
Ive got one of the black plastic facet pumps and haven't had any problems with it...
Its really loud clicking when it runs out of fuel!
Post by Anton » Sat Apr 04, 2015 9:01 pm
I bought a generic thing from my local factors. It makes a horrible noise because it's hard mounted to the inside of the chassis just forward of the tank - I really need to mount it using rubber mounts (ala t-case mounts) instead.
