zukelers
Post
by zukelers » Wed Sep 30, 2015 8:03 pm
would like to put discs on the rear end of my sj... was gonna use my current 413 fronts as they are in reasonable condition.. is their is a better set up for the front?? vented discs?? two pot calipers??
any ideas welcomed
zukelers on Wed Sep 30, 2015 8:05 pm, edited 1 time in total.
Post
by dan_2k_uk » Wed Sep 30, 2015 8:05 pm
LWB 16v Vitara vented discs and calipers.
zukelers
Post
by zukelers » Wed Sep 30, 2015 8:07 pm
is that a straight swap or fettled mounting bracket??
Post
by dan_2k_uk » Wed Sep 30, 2015 10:14 pm
Pretty sure they bolt on.
I've actually got some but not got round to fitting yet. Sort of just waiting until I next have caliper troubles and then I will just put the two best calipers on the rear and fit the Vit ones to the front.
Post
by Anton » Wed Sep 30, 2015 10:39 pm
Make sure you get the right ones, off a 5dr. The 3dr has smaller pistons than the SJ, the 5dr has bigger ones (vit: 48mm, SJ: 51mm Vit 5dr: 53.9mm).
I have a set of 48mm vitara calipers lying around *somewhere* because I bought the wrong ones once.
Post
by donkeychomp » Wed Sep 30, 2015 10:56 pm
Yes I have them in my garage awaiting Andrew's arrival...maybe next year lol
Post
by Anton » Wed Sep 30, 2015 11:02 pm
No, besides those ones!
I honestly can't tell you how many sets of vit/SJ calipers I've ended up with. I think I have about 2 spare sets of Aisin's, although they need *WORK* - and various others, including a set of grand vitara calipers that won't fit anything less than a 16 inch rim...
zukelers
Post
by zukelers » Thu Oct 01, 2015 7:00 pm
cheers gents.. gives me a bit more of an idea what to keep an eye out for when rummaging through the local scrappie.. lwb vit calipers added to the ever growing list??
Post
by Anton » Thu Oct 01, 2015 7:48 pm
Whereabouts in the world are you?
zukelers
Post
by zukelers » Sat Oct 03, 2015 9:13 pm
Anton wrote:Whereabouts in the world are you?
down in kent.. by the med, in st.rood
nr,Rochester
