Headlamp bulb change
Eltoon
Post by Eltoon » Mon Jan 25, 2016 11:15 pm
Ok, so hopefully this isn't really 'technical' :mrgreen: '88 SJ413 - I noticed tonight I have no hi-beam on one side so I guess a new bulb is called for, is this a simple operation? Having just acquired the car I have no manual yet. I'm sure I'll figure it out but a little guidance saves time! Thanks!
Re: Headlamp bulb change
Post by ROBBIE » Tue Jan 26, 2016 8:35 am
Whats it on ? Simple on a SJ, never done a vit
Eltoon
Post by Eltoon » Tue Jan 26, 2016 8:59 am
'88 SJ413
Post by Anton » Tue Jan 26, 2016 12:47 pm
There's a 3 pin connector on the back. Pull it off. Take the bulb out, put the new bulb in, push the 3 pin connector back on.
RickUK
Post by RickUK » Tue Jan 26, 2016 1:06 pm
As above but if its a Halogen bulb that you are replacing it with then caution handling the bulb as any moisture from your finger will kill the bulb when you switch the lights on.
Deceased.
Current wheels.
Eltoon
Post by Eltoon » Tue Jan 26, 2016 1:40 pm
Ok, nice and easy thanks. I've not had a chance to look over the car since i got it the other day, except in the dark last night, Cheers
Post by Anton » Tue Jan 26, 2016 3:42 pm
:doublethumbs:
Eltoon
Post by Eltoon » Tue Jan 26, 2016 6:46 pm
T'was indeed jolly simple...just like me :S
