Deafening transmission noise
Rod4578
Post by Rod4578 » Mon Apr 18, 2016 7:23 pm
Might be a daft question but how noisy should be an sj drive train be ?? Say at 30 to 40 mph mine is deafening
I do have insane turbo Sahara on it 215 r 15
Only asking as I have no comparison exept a road Going freelander
Any help or advise would be great
SlimGrim
Re: Deafening transmission noise
Post by SlimGrim » Mon Apr 18, 2016 7:37 pm
:hahaha: What kinda noise? I thought my UJ was fucked until I actually put my head under mine and found about 12mm of play on both rear wheel bearings :hahaha:
___________________
Rod4578
Post by Rod4578 » Mon Apr 18, 2016 7:54 pm
Its not high pitched bit of whiney noise but more of a loud grumble that seems to come from the whole drive train. I just trying to compare it to a standard sj on mud terrains on a normal road. If u get what I mean lol
Grey Man
Post by Grey Man » Wed Apr 20, 2016 9:45 pm
Hi,
I have a very similar noise on my SJ413, I noticed a week ago that the normally noisy interior (no carpets, sound proofing or frills) had got worse although it still drives well. Local garage believe that a bearing is collapsing or has collapsed in the rear differential. They have asked me to source a scrapped rear diff or axle - quite a tall order as it turns out. The replacement must be a 413. It would seem rebuilding the bearing maybe an easier option.
Anyone know were I can get the bearings and oem numbers or does anyone have a spare rear dif for sale?
many thanks
Post by dan_2k_uk » Thu Apr 21, 2016 6:02 pm
The pinion bearings are available from normal bearing shops pretty cheaply the side bearings are a little more expensive but its likely it will only be the pinion bearing that has failed. The pinion seal and crush sleeve would have to be sourced from Suzuki as the seal has an extra lip that won't be present on a standard seal the same size.
Post by dan_2k_uk » Thu Apr 21, 2016 6:05 pm
The bearing info can be found part way through this axle sticky.
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
Post by twiss » Thu Apr 21, 2016 7:13 pm
If you are diagnosing issues with the transmission, I sometimes find it easier to put the back axle on axle stands, remove the front prop (because im paranoid) and the rear wheels, then put it in 2WD, 5th gear with the engine running and slowly release the clutch...
Everything will start spinning and it makes it easy to hear where its coming from... just watch out you dont get anything caught it something spinning!
