Thought i would start a build thread on my two 410's i've got as i thought you might be interested.
Tin top van 410 1987?
Soft top 410 1984
I'll start with the soft top.
I got this free in January with my brothers discovery which is still stuck in the woods we got it from
Towed it home, fixed the positive battery terminal and it fired up after not running in 18 months. Gave it a clean, drove it around and just used it to move stuff around my parents property for a bit. until last week i hadn't done much except attempt a virtual lift on one wheel arch but ran out of welding gas (stupid hobby bottles only last like 20 minuted). Then the other day i took it to bit as i'm going to paint the chassis and do the body work, i'm also going to get a big gas bottle.
So then i picked up my sj van body last Saturday from Dorset and also a soft top 410 to swap all the running gear over. Took about nearly all day to pick them both up but eventually got them home. I haven't done much so far except fit a new door and wind screen, but plan on getting most of the work done over the summer.
It has rot in the usual places and some added rot on the spring mounts, plus the last owner seemed to like using the angle grinder a little too much and cut the one of the front spring mounts, steering box arm and a nice hole in the rear floor. Front wings are a bit worst for wear so i think they will need replacing
Should be a fun project
Here are some pics as i know you all love pics
And the new 410 soft top
And the current state of my first 410, still can't understand why i took it apart
Gets its own little shelter though!
So there they are!
I think i'm going to modify the soft top moderately but keep the van as standard as i can.
I've got 7 weeks of to crack with it though
Pete
