Steering wheel removal
EricG
Post by EricG » Mon Sep 05, 2016 11:59 am
Hi. I need to remove my steering wheel and the manual says to use a special tool, which I don't have. Is there any way to remove the wheel without this tool?
______________________________
Keep on keeping on -- with a Zook!
Due to the current economic climate, the light at the end of the tunnel has been switch off.
Re: Steering wheel removal
Post by ScottieJ » Mon Sep 05, 2016 12:50 pm
Undo the centre nut but leave it on by a few threads, give the steering wheel a good wiggle with both hands while pulling it, it should come off.
Whatever you do make sure you leave the nut on a few threads, you'll thank me later when you don't end up smashing the wheel into your face because you didn't leave it on :lol:
zook123
Post by zook123 » Mon Sep 05, 2016 1:10 pm
And remember, if you have an airbag, remove the battery at least 20mins before removing.!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
SherwoodNash
Post by SherwoodNash » Mon Sep 05, 2016 1:10 pm
As Scottie says, plus, I found WD40 soaked in for an hour beforehand can help, as applying heat (gun or dryer) can be dodgy as there's plastic in the area of the nut.
Also, sitting in the drivers seat, I placed a temporary footrest, ie block of wood, under my feet, so that the knees act as another pushing force behind the wheel.
This, along with rocking the rim with my hands, helped me with a stubborn spline join.
Post by Jordi » Mon Sep 05, 2016 4:18 pm
Home brew bearing puller did the job for me.
Post by ROBBIE » Mon Sep 05, 2016 4:28 pm
Loosen nut bang wheel with palm of hands at the bottom often works
EricG
Post by EricG » Mon Sep 05, 2016 8:30 pm
Thanks to you all for your help. Tried your way Scottie - came off easy. Was planning to fit new indicator/wiper switch but found out that the old one isn't at fault so no idea why indicators and hazards not working.
MOT runs out Wednesday. There is too much wrong with the old wreck (especially there is a lot of rot) so regretfully decided that it must come off the road.
If I had the skills maybe I could do it up myself.
Post by ROBBIE » Tue Sep 06, 2016 8:16 am
The joy of an old Suzuki is learning the skills to keep it alive :thumbup:
zook123
Post by zook123 » Tue Sep 06, 2016 8:25 am
Have you checked the fuses?
SherwoodNash
Post by SherwoodNash » Tue Sep 06, 2016 10:33 am
ROBBIE wrote:The joy of an old Suzuki is learning the skills to keep it alive :thumbup:
So true Robbie! I knew nuttin' 2 years ago, today, now let me see..........up to 3.5 spanners maybe? :lol:
