SJ410 lighting wiring
On a 1988 SJ410 is the side lights' wiring split side to side? I've got a funny going on with the side lights/indicators - I've lost power to a front side light and the rear light interacts with the indicator both on the same side..?
Re: SJ410 lighting wiring
It's normally bad earths that make the lights play silly wankers
Yes that's exactly what they're doing!Darrell wrote:It's normally bad earths that make the lights play silly wankers
I will look at earths but I'm also mystified as to why there's no volts in one of the connectors on that side, hence wondering if they were separately fused.
I believe a 88 410 lights are wired same as a 413. Yes fused either side, like so..
- headlightwiring.jpeg (65.04 KiB) Viewed 8930 times
Aha yes I've been looking at a dead green and red wire so that makes sense, thanks for that.
fyi, I think the common name for the lights all flashing stupidly is "disco lights"
Notedtwiss wrote:fyi, I think the common name for the lights all flashing stupidly is "disco lights"
