Oil light reset
Oil light reset
I have a2016 Diesel Vitara 4x allgrip auto and want to change the oil myself. How do I reset the oil change light. The YouTube instructions don't work.
Anybody have the correct method without a Dealer computer.
Re: Oil light reset
Had to get the dealer to do it
Re: Oil light reset
Any garage with a generic reset tool can do it, not a job you can do yourself. My local independent reset mine.
Re: Oil light reset
Anyone with an OBD2 reader should be able to do it. *should*...
Re: Oil light reset
Anyone found a solution to this yet? Thanks in advance.
Re: Oil light reset
Had to go to the dealer. No work around available for the diesel engine.
Re: Oil light reset
1. Foot on accelerator and keep it depressed.for entire procedure.
2. Power on button twice to switch ignition on but not engine.
3. Press Left trip button until odometer B is selected.
4. Press and hold Right menu button.
5. Pump brake pedal 3-4 times and wait.
6. When Change Oil Warning has cleared, release the accelerator.
Job done... It may take more than 1 attempt.
Re: Oil light reset
Re: Oil light reset
Thanks Parkey72. ..it worked perfectly
