INDICATOR/HAZARD RELAY - HELP PLEASE!
EricG
Post by EricG » Tue Mar 22, 2016 6:52 pm
Hi All:
My indicators/hazards on my 'P' reg Vitara have all but stopped working. Sometimes they will flash once, or maybe a few times but mostly don't work at all. The relay is only a few months old but before I get back to the seller can anyone please tell me if there is a way to test it to make sure it is the relay and not the switch?
Thanks for any help,
Eric
______________________________
Keep on keeping on -- with a Zook!
Due to the current economic climate, the light at the end of the tunnel has been switch off.
Re: INDICATOR/HAZARD RELAY - HELP PLEASE!
Post by Anton » Tue Mar 22, 2016 8:22 pm
A new relay is a couple of quid, the easiest way to check is to whack a new relay in, I'd say. Or if you know a mate with a Vit, put your relay in his (or his in yours) and see if the problem goes away.
EricG
Post by EricG » Tue Mar 22, 2016 8:30 pm
Thanks Anton. The last one cost me 12 quid - didn't want to fork out that much for another if I don't need to .
Post by Anton » Tue Mar 22, 2016 10:40 pm
http://www.ebay.co.uk/itm/271404234337
That's what I got, but I don't know if it'll fit a Vitara. Fit my SJ, works fine. But as I said, you'll probably want to test yours first, because if it's under warranty then you can just get another one.
Post by ScottieJ » Wed Mar 23, 2016 9:03 am
Anton wrote:http://www.ebay.co.uk/itm/271404234337
Check the polarity before ordering......I'm not sure if all Suzukis use the opposite polarity but that one linked is the wrong polarity for mine.
I usually order this one.
http://www.ebay.co.uk/itm/290726947765? ... EBIDX%3AIT
Post by dan_2k_uk » Wed Mar 23, 2016 10:41 pm
Jap and Spanish SJs use the opposite polarity.
I've got a digital one for LED conversions sat here where I duplicated an eBay order I did for someone else with a Jap truck only to find out Spanish fuseboards are the opposite way round and had to order another.
EricG
Post by EricG » Thu Mar 24, 2016 9:45 pm
Thanks for your help guys.
Anton and Scottie - both the ones you gave a link to are for LEDs - mine are not.
I need to check all my bulbs and bulb holders and wires etc as I am still not sure if it is the relay or not.
I have noticed that one of the front bulbs is badly corroded so am wondering if that could be anything to do with the problem.
Post by Anton » Thu Mar 24, 2016 11:49 pm
LED relays work with LEDS and normal bulbs.
Post by twiss » Fri Mar 25, 2016 12:28 am
Anton wrote:LED relays work with LEDS and normal bulbs.
Yes it just won't flash quickly if a bulb is out
Frenchy
Post by Frenchy » Tue Sep 20, 2016 3:05 pm
I'm having problems with the indicator relay.it's a Spanish model and the relay fits into the top of the fuse bank cover.When I bought it the indicator would fail intermittently due to the relay being slightly loose.In the end it failed completely.The new one I bought was fine for a while then started to do the same thing,I've run a bit of solder over the spades but it still loosened up.Anyone know if there is a relay with larger spades available or will I just have to carry on with the cardboard wedge method? ;)
