Fuselink info
Fuselink info
Another diagram.
- Fuselink 2.jpg (72.38 KiB) Viewed 56128 times
- Fuse link wire.jpg (79.27 KiB) Viewed 56128 times
- FusibleLink-1.jpg (44.39 KiB) Viewed 56128 times
- 36740-80000.jpg (10.49 KiB) Viewed 56128 times
- 2011-11-17_170709_burnt_fuse_link.jpg (22.97 KiB) Viewed 56128 times
- Suzuki SJ samurai fuselinks.jpg (135.81 KiB) Viewed 56125 times
Re: Fuselink info
I know a few of you have replaced these with larger wire and fuse holder/fuse.
I've seen 30 or 40 amp used.
Feel free to add any info on what you have done
Re: Fuselink info
According to the tinternet the green is 0.5mm and rated at 13amp continuous and 40 amp blow.
Seems low to me if you had the heater fan - lights - wipers etc on must be near the limit ?
I would think a fuselink is much slower blowing than a standard blade fuse so could take a little overloading for some time before it melted. However a dead short would melt it in seconds
I dunno
Here's some normal blade fuse info anyway.
I dunno
- fuses.png (30.85 KiB) Viewed 56119 times
Re: Fuselink info
I had a 35A blade fuse in mine and blew it a few times. 40A seems to be the magic value.
- Edweird
Re: Fuselink info
Darrell wrote:According to the tinternet the green is 0.5mm and rated at 13amp continuous and 40 amp blow.
I've got a 30 Amp blade fuse in mine and I ran it for about 5 minutes the first time I put it in with the engine, wipers, all lights, internal fan, fag lighter etc. and it didn't blow. I've driven home at night in the rain a few times now with music and the heater on and it's still fine. It's been in for at least 2 or 3 months.
Re: Fuselink info
Thanks for the input guys. I see most standard blade fuses only go to 30amp but a few people sell 35 and 40 amp ones. I also see most blade fuse holders are only rated at 30 amps but again if you shop around you can find 40amp ones. Alternatively a "Maxi " blade fuse and holder could be used.
Re: Fuselink info
Littelfuse have a fuse specifically designed for this purpose:
http://www.littelfuse.com/~/media/Autom ... %2032V.pdf
http://www.littelfuse.com/~/media/Files ... design.pdf
- ianedwards
- SCUK Addict
Re: Fuselink info
Doh, the link on mine was all joined with blocks so ive soldered a nice new wire in not realising what it was actulay for. oops. shall get a 40 amp fuse to go in line lol.
Stupid git lol
Stupid git lol
Ian.
Ian.
Re: Fuselink info
40amp fuse with 50amp rated holder(a few quid of amazon ) on mine have a/c and power strering kept bolwing 35s
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
