Transmission brake swapping
Daft question, fairly sure i know the answer.
Does the transmission handbrake just unbolt off one transfer case and bolt onto another?
Getting a rocklobster next month but i dont want to take my Samurai off the road whilst it's done.
I'm thinking take transfer box out of my KJA send it to get modded. When its returned that will go into my samurai. Then i can just bolt the transmission brake onto the old Samurai box and put it back into the KJA. Everyone follow?
Unless someone has another 413 transfer box for cheap? Save me messing on n
Re: Transmission brake swapping
Looking at all the pics I have, they all show the transfer boxes to have the threads/fixings for the drum backplate. I assume you can swap any about (but I don't know for sure).
From the online manual And a photo from my workshop manual
- From my manual.JPG (208.63 KiB) Viewed 5826 times
Yes they all SJ tboxes are tapped for the tbox handbrake
Sound!
I'll just take the KJA box out. Saves the sammi being laid up. Unless i can afford to tax and insure the KJA
Then i can use that as my daily drive for a bit
Few, that's a massive relief, as I've just brought a tbox brake from the parts for sale section to put on my Sami when I do the rear disc conversion! Just assumed that they were a standard fit!
Are they easy enough to fit or will it need a bit of head scratching?
John
John
you will need Chuck Norris to undo the nut that holds the drum/flange on. Apart from that its all good.
Trotter has made a tool to hold the drum while you get a breaker bar on the nut.
Let me know if you need it and I will drop it in if I am working near yours.
Thanks dan will do, hopefully the brakes in the post, if only the postman had an sj he would be able to deliver it for me!
Wish mine was up and running so I could get out and enjoy the snow! Tempted to buy your mates while mines off the road!
I had to make a bracket, that bolted to the body, to hold the hand brake cable in place on my sammy
Another question on this. Will my Samurai rear prop still be ok? Or do i need a different end to mate it to the drum?
As long as it's an early sammy prop with the 8mm bolts it will fit
And as long as the drum isn't off a really early sj410 with skiny props
