Help please High CO emmission from G16A 8v single EFI
npjrogers@btinternet.com
Post by npjrogers@btinternet.com » Mon Apr 01, 2013 8:19 pm
My CO IS 3.56 percent and an MOT fail. Pass would be 3.50 percent. My minimum idle seems to be 1000rpm. PCV is clean. What would be the most likely cause of my High CO?
Nick
Belfast
Re: Help please High CO emmission from G16A 8v single EFI
Post by Jordi » Mon Apr 01, 2013 8:21 pm
I don't know the tech exactly. But when was it last serviced?
Post by npjrogers@btinternet.com » Mon Apr 01, 2013 8:41 pm
Has had oil and filter replaced and plugs cleaned and timing checked in last 100 miles.
Post by Darrell » Mon Apr 01, 2013 8:47 pm
I believe a vacuum leak is often responsible for high idle and CO.
Rhinoman who has recently joined the forum :thumbup: will be the most knowledgeable person and hopefully will be along to help.
I assume the check light is not on.
Dam ECU's are beyond me :er:
vit dia.jpg (397.74 KiB) Viewed 6435 times
Post by npjrogers@btinternet.com » Mon Apr 01, 2013 11:03 pm
Rhinoman has an identical Vit to me so I would love to hear his thoughts. I suspect a vacuum leak also.
Nick
Belfast
Post by npjrogers@btinternet.com » Tue Apr 16, 2013 10:02 am
Darrell wrote:I believe a vacuum leak is often responsible for high idle and CO.
Rhinoman
Post by Rhinoman » Tue Apr 16, 2013 1:03 pm
Did you buy a tool from me a while back? what do your fuel trims and O2 sensor readings look like?
