My CO IS 3.56 percent and an MOT fail. Pass would be 3.50 percent. My minimum idle seems to be 1000rpm. PCV is clean. What would be the most likely cause of my High CO?
Nick
Belfast
Help please High CO emmission from G16A 8v single EFI
- npjrogers@btinternet.com
Re: Help please High CO emmission from G16A 8v single EFI
I don't know the tech exactly. But when was it last serviced?
Has had oil and filter replaced and plugs cleaned and timing checked in last 100 miles.
I believe a vacuum leak is often responsible for high idle and CO.
Rhinoman who has recently joined the forum
will be the most knowledgeable person and hopefully will be along to help.
I assume the check light is not on.
Dam ECU's are beyond me
- vit dia.jpg (397.74 KiB) Viewed 6452 times
Rhinoman has an identical Vit to me so I would love to hear his thoughts. I suspect a vacuum leak also.
Nick
Belfast
Nick
Belfast
Darrell wrote:I believe a vacuum leak is often responsible for high idle and CO.
Rhinoman who has recently joined the forumwill be the most knowledgeable person and hopefully will be along to help.
Did you buy a tool from me a while back? what do your fuel trims and O2 sensor readings look like?
