HELP
- suzukisteve
- Suzuki Guru
Re: Spacer on the car only quick and probs simple
the spacer itself should pull off then you can unwind the studs after. if its stuck on give it a good squirt up with wd40 or the equivalent and leave to soak in for a bit and try again
pickle power!
oh okay i think they may be stuck then as they have been soaked in clay thanks
How do i get these bits of now ??
- 37.jpg (179.14 KiB) Viewed 5888 times
Re: HELP
With a bar put across 2 and levering against the floor to stop the hub spinning just use a deep socket or a ring spanner.
Re: HELP
Bleeding it all part of the experience Ollie. By the end of the week i'll lucky to have skin on my hands.
Re: HELP
Ollie you want to get yourself a decent socket set and set of spanners (at least 8-19mm) before you buy any more parts, adjustable spanners shouldn't go anywhere near a vehicle unless its an emergency, they are aweful things and spend most of their life rounding off bolts rather than undoing them, I've got a large selection of adjustable spanners and I can't actually remember the last time I used one
Oh and this should be in wheels, tyres and brakes not the bar
