HELP
OllieSJ
HELP
Post by OllieSJ » Sun May 26, 2013 7:42 pm
So this has confused me of how to get it off ??
suzukisteve
Re: Spacer on the car only quick and probs simple
Post by suzukisteve » Sun May 26, 2013 7:44 pm
the spacer itself should pull off then you can unwind the studs after. if its stuck on give it a good squirt up with wd40 or the equivalent and leave to soak in for a bit and try again :thumbup:
pickle power!
OllieSJ
Post by OllieSJ » Sun May 26, 2013 7:48 pm
oh okay i think they may be stuck then as they have been soaked in clay thanks
OllieSJ
Post by OllieSJ » Mon May 27, 2013 1:22 pm
How do i get these bits of now ??
Re: HELP
Post by dan_2k_uk » Mon May 27, 2013 2:16 pm
With a bar put across 2 and levering against the floor to stop the hub spinning just use a deep socket or a ring spanner.
Re: HELP
Post by Darrell » Mon May 27, 2013 2:26 pm
Or get someone to put their foot on the brake ;)
Re: HELP
Post by turbo-tom » Mon May 27, 2013 11:14 pm
or get a rattle gun and buzz them off!
OllieSJ
Re: HELP
Post by OllieSJ » Mon May 27, 2013 11:16 pm
Nearly done them all with an adjustable and a nice slice out of my finger
Re: HELP
Post by Jordi » Mon May 27, 2013 11:23 pm
Bleeding it all part of the experience Ollie. By the end of the week i'll lucky to have skin on my hands.
Re: HELP
Post by ScottieJ » Mon May 27, 2013 11:29 pm
Ollie you want to get yourself a decent socket set and set of spanners (at least 8-19mm) before you buy any more parts, adjustable spanners shouldn't go anywhere near a vehicle unless its an emergency, they are aweful things and spend most of their life rounding off bolts rather than undoing them, I've got a large selection of adjustable spanners and I can't actually remember the last time I used one :lol:
Oh and this should be in wheels, tyres and brakes not the bar :thefinger:
