samurai hesitating
Rhinoman
Re: samurai hesitating
Post by Rhinoman » Tue Jan 21, 2014 12:48 pm
That may be a light for catalytic converter overtemperature (below), usually thats down to a bad sensor in the cat. That type of cat isn't available over here so you may as well pull the bulb.
This one?
john86
Post by john86 » Tue Jan 21, 2014 1:49 pm
Yep thats the one comes on a soon as i Start up would that be causing the hesitation
Rhinoman
Post by Rhinoman » Tue Jan 21, 2014 1:53 pm
Unlikely I would think, if its on at the start (cat cold) then its a sensor issue.
john86
Post by john86 » Tue Jan 21, 2014 2:07 pm
An o2 sensor is 60quid i might check around a bit more before I take the plunge thanks again rhinoman appreciate the help
john86
Post by john86 » Sat Feb 08, 2014 9:36 am
Thanks again for the help rhinoman the hesitation was down to the clutch slipping.The car is running much better but using a lot of fuel do you think the cat warning light could be linked to the high fuel consumption
