Hi everyone having trouble with the release bearing on my 410 when I press the clutch down its fine but when I release the clutch there's a terrible whining I took it to a mechanic and he said the release bearing wasn't coming back far enough? Is there meant to be a pin or some sort holding the real ease bearing the two forks in the gearbox to pull it back? If there we're do I find them?
Release bearing
Re: Release bearing
sounds like your release bearing is buggered anyway
there are indeed two forks with a pin on one of them... (on a 413 anyway)
the release bearing hooks onto the little pin
if you are taking the gearbox off i would consider putting a new one in anyway (or possibly a whole new clutch if the price was right)
Re: Release bearing
Ahh okay so the 410 dosnt have a pin on the 2 forks? So how would it relase?
Re: Release bearing
It probably will but I can't say for sure as ive never looked at a 410 box in detail
I've managed to snap the pin out of mine before... think i fixed it with a tiny bolt somehow!
Re: Release bearing
I've posted this up before (but can't find it) so..
- Early 410 clutch bearing.jpg (86.41 KiB) Viewed 5444 times
- Later 410 & 413 clutch bearing.gif (38.93 KiB) Viewed 5444 times
Re: Release bearing
Dry / worn bearing
Re: Release bearing
I don't know how I can re attach the bearing to the forks? Any ideas
Re: Release bearing
What's broken/missing on yours.
Is yours the early or later type.
The early spring clips are prone to breaking I've read..
- M-09448-12005-SS.jpg (5.08 KiB) Viewed 5405 times
