got an old su carb and mount from my old engine, it was a bit tatty and had some cable ties holding it together but still worked ok, anybody know the value of it if its worth selling or keeping it?
thanks
SU Carb Value
SU Carb Value
A Newbie with a 1988 Samurai Hard-Top
Re: SU Carb Value
SU carb elbow adaptor about £15. SU carbs go from about £35 to £75 depending on condition and setup.AshR1 wrote:got an old su carb and mount from my old engine, it was a bit tatty and had some cable ties holding it together but still worked ok, anybody know the value of it if its worth selling or keeping it?
thanks
Re: SU Carb Value
thanks, well if anybody is interested have the elbow and the carb but no hoses, can have them both for £40, i'll get some pics up of the carb though, like i say it worked but its not the best example of one
Re: SU Carb Value
it did have a sticky throttle but i just used a spring and washer on it and it worked fine after
- 10644977_10153206718998765_4377639098761648097_n.jpg (74.82 KiB) Viewed 5241 times
- 10665158_10153206720083765_5425796797493810620_n.jpg (70.76 KiB) Viewed 5241 times
- 10409350_10153206720928765_9069620343988549168_n.jpg (65.66 KiB) Viewed 5241 times
Re: SU Carb Value
That's an old HS style carb, most people want HIF carbs.
Re: SU Carb Value
Its just an H carb actually
The HS carb has an external fuel hose connecting the float chamber to the carb...
Re: SU Carb Value
If that's the case, might actually be worth more to the MG, Rover, Jag or Austin communities.
