SU Vacuum hole
Gardiner
SU Vacuum hole
Post by Gardiner » Fri Nov 30, 2012 7:05 pm
I see on posts that some re drill vaccuum pipe hole, my SU has the hole slightly air filter side of body does this still need drilling.
Re: SU Vacuum hole
Post by ScottieJ » Fri Nov 30, 2012 11:18 pm
Isn't that hole on the bottom of the carb? Normally the vac takeoff is on the top?? Can you take a pic of the vac point on the outside?
Gardiner
Re: SU Vacuum hole
Post by Gardiner » Sat Dec 01, 2012 7:12 am
Yes it is the bottom of the carb but it still just (Only Just) air filter sde of the body
Re: SU Vacuum hole
Post by ScottieJ » Sat Dec 01, 2012 9:17 am
As long as its on the air filter side then it's fine.
This is where the vac take off normally is
is yours like this??
Re: SU Vacuum hole
Post by Tramp » Sat Dec 01, 2012 5:42 pm
I had an SU that I was going to fit & that was the same with the vac takeoff point in the correct position, you should be fine with that!
Gardiner
Re: SU Vacuum hole
Post by Gardiner » Sat Dec 01, 2012 7:01 pm
Yes mine is the same as pic 2.
All being well Sunday is the first fire up day !!!!!!!!!!!!!!!!!!!!!!!!!!
