Vitara Gearbox / Transmission Oil
Post by ScottieJ » Mon Aug 12, 2013 10:37 am
Many People make the mistake of using regular GL-5 in the Vitara gearbox, make sure you don't! It is safe to use in the transfer box though ;) If you can't find GL-4 then there are Yellow metal safe alternatives available.
Re: Vitara Gearbox / Transmission Oil
Post by donkeychomp » Mon Aug 12, 2013 10:20 pm
Ta for the tip Scottie! Changing my oils this weekend...glad I read this!
fatdaz
Post by fatdaz » Thu Mar 20, 2014 9:58 am
same go for the td commercial dude?
2 samurais. 1 vit and now a vit commercial :)
Post by ScottieJ » Thu Mar 20, 2014 11:05 pm
fatdaz wrote:same go for the td commercial dude?
Yes it runs the same transmission :thumbup:
Post by Anton » Mon Mar 31, 2014 2:29 am
I'm now wondering if the oil I put in my axles is going to be safe for an ARB. I used the recommended gear oil for SJ axles, but I don't know if it's yellow metal safe, or if ARB's need yellow metal safe oil...
Post by ScottieJ » Mon Mar 31, 2014 1:48 pm
Pretty sure arbs just need normal gl5
Post by Anton » Mon Mar 31, 2014 2:34 pm
Probably, but I'm going to email ARB to check, better safe than sorry.
Post by ScottieJ » Mon Mar 31, 2014 7:03 pm
Anton wrote:Probably, but I'm going to email ARB to check, better safe than sorry.
Normal diff oil :thumbup:
http://www.arb.com.au/media/products/ai ... s/6-01.pdf
Post by Anton » Mon Mar 31, 2014 7:05 pm
You, sir, are a scholar. And a gentleman. :doublethumbs:
Post by ScottieJ » Mon Mar 31, 2014 7:10 pm
No worries, I have ARB manuals for the diff and compressor in PdF format on my work PC as well if you want copies?
