Wider Tyres sticking out of arches, legal?
Sj410red
Post by Sj410red » Mon Sep 02, 2013 11:32 am
Hi all, just fitted 32mm spacers to my sj410, it has the smaller plastic arches fitted but the tyres protrude upto 1" looking from above, is this legal? I have trawled many forums and seems to be a grey area that it would pass an mot ok but plod may think different. Any answer please, thanks Richard.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
Re: Wider Tyres sticking out of arches, legal?
Post by ScottieJ » Mon Sep 02, 2013 11:48 am
If you get a copper on a bad day (or a jobs worth) he will pull you for it. It's a non-endorsable (no points but fixed penalty fine) offence. Code 380 under construction and use regs. "No wing/mudguard fitted"
But he's you are correct it will pass an MOT as it is not covered in the MOT.
As far as I'm aware you can have the sidewall bulging out but all tread surface that makes contact with the road must be covered, I've never had any issues with a few mm of tread sticking out slightly.
suzukisteve
Post by suzukisteve » Mon Sep 02, 2013 1:12 pm
extended arches to be safe in my opinion :thumbup:
pickle power!
Post by turbo-tom » Mon Sep 02, 2013 2:34 pm
my disco and suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
Post by ScottieJ » Mon Sep 02, 2013 3:17 pm
turbo-tom wrote:suzuki the wheels stick out a little with the extended arches mr plod aint pulled us yet!
Might help if it was actually driven on road :thefinger:
suzukisteve
Post by suzukisteve » Mon Sep 02, 2013 3:39 pm
:hahaha:
pickle power!
Post by Edweird » Mon Sep 02, 2013 3:42 pm
:hahaha:
And they can't dear to look at the Land Rover long enough to notice.
88SJ
Post by 88SJ » Mon Sep 02, 2013 3:55 pm
If you like the look leave it pal. If you like extended arches get some on and you will be all legal
I run 235/75x15 on 7" alloys that stick out about 1" with the offset. They look cool and I have never had any bother from the cops
windsor
Post by windsor » Mon Sep 02, 2013 4:35 pm
Mine stick out about a inch and never had any hasstle from it will have to go wide arches with new tyers tho 4inch sticking out wont go down well
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
dazerede
Post by dazerede » Mon Sep 02, 2013 4:54 pm
This is what mine looks like 410 axles 32mm solid spacers and 235/75/15 tyres
4” calmini lift kit :)
