Need to fit a TRE sometime soon and ideally want to fit a new rod too but struggling to find the actual rod.
Might brave suzuki but ideally need the part number first.
Cheers (most likely thanks to Darrell)
Track Rod and TRE part number for Samurai
Re: Track Rod and TRE part number for Samurai
Fooking expensive i believe.
Twiss may be the guy to speak too.
Yeah, tried to con Scottie into bringing one back but failed.
Might ask a polish lad i know for a price off his brother who has a Zuk.
Again, part number makes it much easier to explain.
In the past this was the only site I found selling steering rod and ends.
LHD and RHD , SJ (narrow) Samurai (wide) , so you would need to careful to get the correct part.
http://www.euro4x4parts.com/suzuki_part ... ie_rod_end
I think that I might have a few spare track rod ends if you want one, mate. Not sure I can help you with the actual rod though, I have a spare but I have the feeling I'll be needing it - I think I might have bent my current one, and I don't like the idea of trying to straighten it...
I'm not going to risk posting the part numbers as I can't confirm this diagram is SJ or Samurai. As least it will help identify the part names required.
- ju.jpg (242.77 KiB) Viewed 8286 times
Id have to measure the ones in the barn but
Im sure that 413 and samis are the same its
Just a longer adjuster fitted between the tie rod
And tre. I think.
And tre. I think.
You want me to just post you one Jordi? I think they are €55 for both samurai rods (45 i think for narrow track) including the TRE
Not sure on postage but I'm willing to bet its a lot cheaper than buying the bars in the UK.
Tbh I could get my parts guy to send it to you in the UK as he uses DHL a lot
