Suzuki sj 410 from Cornwall PROJECT Never Ending Project
- dazerede
Re: Suzuki sj 410 from Cornwall PROJECT Never Ending Project
Yep ok I will just bolt them on how they are
I.just can't wait.to fit them but I ain't got much.time on the evenings as I need it to get to work and college
4” calmini lift kit
4” calmini lift kit
- dazerede
But I have fitted the new springs and tadah they are 1.5-2 iinches higher than.my old ones
- IMAG0246.jpg (1.49 MiB) Viewed 6342 times
- IMAG0249.jpg (1.76 MiB) Viewed 6342 times
4” calmini lift kit
4” calmini lift kit
- suzukisteve
- Suzuki Guru
lookin good dude, where did you get em from?
rear bearings are easy to get hold of and not to bad to fir either
pickle power!
- dazerede
Are all 410 bearings the same as I have a Spanish 410 rear axle on my zook
Got them of eBay http://www.ebay.co.uk/itm/SUZUKI-SJ410- ... 0850654254
The hardest bit is getting the shaft out I had a spare axle so I thought I would take that one out and that one was easy but the shaft in my zook is stuck in.there
4” calmini lift kit
4” calmini lift kit
- suzukisteve
- Suzuki Guru
can you use a slide hammer of the like on it? might give it enuf force to get it to move mate.
you gonna do a ruf then?
pickle power!
- dazerede
I plan to do ruf in a coupe of mounts but funds is getting a bitblow so can't for a while
I bolted a pice of angle metal on too 2 the Drum nuts and I put a car sissor jack in bertween the spring.and the angle metal and all it is doing is bending the meatal I gave up for the day about 2 hours ago but I.will have a better go tmoz
What do I need to get to do the rear wheel bearing
Wheel bearing
Spacer
Oil seal
Wheel bearing
Spacer
Oil seal
4” calmini lift kit
4” calmini lift kit
- suzukisteve
- Suzuki Guru
if you buy a bearing kit it should have everything you need in it. gimme a sec and ill find a part number
pickle power!
- suzukisteve
- Suzuki Guru
here we go: adk88204 or brt973
should be able to get either from most factors
pickle power!
A new retaining collar, often part of a kit!dazerede wrote:I plan to do ruf in a couple of mounts but funds is getting a bit low so can't for a while
I bolted a piece of angle metal on too 2 the Drum nuts and I put a car scissor jack in between the spring.and the angle metal and all it is doing is bending the meatal I gave up for the day about 2 hours ago but I.will have a better go tmoz
Wheel bearing
Spacer
Oil seal
Maybe a brake pipe spanner, unless your backplate has the section that comes out.
A ordinary spanner may do, but once the nut is rounded off its a pain.
A angle grinder.
Access to to press.
- mHX1oYyTNWl3xSJKj5t0deg.jpg (6.8 KiB) Viewed 6311 times
- Rear wheel bearing diagram.jpg (365.94 KiB) Viewed 6311 times
- dazerede
Right I give up
I have tried it this way and no luck my other shaft came out piece of piss a while back using it this way I just don't understand Chears Darrel I might aswell buy 2 kits just incase my other bearing goes in my rear axle
- IMAG0250.jpg (1.7 MiB) Viewed 6298 times
- IMAG0251.jpg (1.45 MiB) Viewed 6298 times
- IMAG0252.jpg (1.65 MiB) Viewed 6298 times
4” calmini lift kit
4” calmini lift kit
