SJ413 1989 Ignition Module - Where?
marcusj
Post by marcusj » Sun Aug 24, 2014 10:08 am
Hi
I'm buying an SJ413 here in Spain. I need an ignition module (the black box thingumies that are attached to the distributor that replace the function of the points on an older vehicle). The module in the vehicle I'm looking at is blown. I've tried the local Suzuki dealer who says that there are no new parts. The local scrap yards are drawing a blank.
I need to source one from, e.g. mail order from U.K. or does anybody know any alternatives, e.g. an equivalent part I could pull off another vehicle that should fit the distributor or an aftermarket kit or from a scrap specialist? The unit comprises a pickup coil connected to a module containing the transistor switching module that switches the low tension side of the coil.
I just need something to get going - I'd even fit an old points style distributor if that would get me going - after that I can work on a less-bodgy solution - if necessary!
Marcus
Re: SJ413 1989 Ignition Module - Where?
Post by Darrell » Sun Aug 24, 2014 11:49 pm
I can't find anybody selling the generator assembly. I think you may be best to try and find a used distributor complete and use it or rob the part required.
Post by Darrell » Mon Aug 25, 2014 12:01 am
On some I believe the generator and ignitor are connected by 2 screws (as shown above) but not listed as separate part numbers.
Mine are soldered together like this
Rhinoman
Post by Rhinoman » Mon Aug 25, 2014 8:12 pm
I think the 'Do not Remove' marking gives a clue as to why its not available separately, I would recommend seeking out a used, complete, distributor.
Post by Darrell » Mon Aug 25, 2014 8:40 pm
I always assumed "do not remove" ment the dust covers ?? ;)
marcusj
Post by marcusj » Mon Aug 25, 2014 9:41 pm
Would an SJ410 distributor fit? Or an older, points-style distributor (assuming that earlier MY's had those) from SJ413 fit? I want to widen my net!
marcusj
Post by marcusj » Tue Aug 26, 2014 11:19 am
Jordi! You tried to send me a PM, matey. Apparently I'm not 'sufficiently active' on the forum to be allowed to even read a PM yet. :(
Post by Jordi » Tue Aug 26, 2014 11:52 am
Should be able to read it now.
