Tom's 85' SJ413 (Shake,Rattle,Roll) NOW UP FOR SALE
Re: Tom's 85' SJ413 Build- NOW FINISHED :D
Watts divided by volts = amps
160/12 = 13.3amps
A standard 30-40amp relay will work fine
160/12 = 13.3amps
- turbo-tom
Darrell wrote:Watts divided by volts = amps
160/12 = 13.3amps
okay thank you darrell so would that be a relay for each fan? or would one relay be okay for two fans?
Tom
Ford Fiesta ST
Ford Fiesta ST
Looking good! like the front end and what you've done with the tank in the back. Love how busy the dash looks as well, be scared to touch anything in case i got ejected haha
good job!
good job!
- turbo-tom
Sorry Scott just seen this! and i shall nowScottieJ wrote:Im pretty sure my relays are 30 amp?
You need to change the title of the thread too, sjs are never finished
And Thanks man! yeah im pleased how it turned out tbh , and Yeah my dashboard has had a lot of thinking behind it! , and you wont get ejected promise!!!Ricky-410 wrote:Looking good! like the front end and what you've done with the tank in the back. Love how busy the dash looks as well, be scared to touch anything in case i got ejected haha
good job!
Tom
Ford Fiesta ST
Ford Fiesta ST
- turbo-tom
Re: Tom's 85' SJ413 Build- Starting again!
Speaking about dashboards i have chopped more out of it! think of getting a custom dashboard made because there is no room on the Sj413 but its fine for now so im sure it will stay!.
it consists of new main engine cut out switch, winch cut out , winch in , winch out (each with warning lights) , and two aux 12v sockets for phone charging etc
Also being that i have taken out my heat controls i kept the main switch to turn the windscreen blower on and off!,
~Anywhoo baack on with the cooling system im half way through my Vitara rad instalation.
removed vicous fan and painted pulley yellow
and these are my electric fans there the cheap ones but i will see how they go. just need to fabricate some brackets and it should be in
Tom
Ford Fiesta ST
Ford Fiesta ST
I was thinking of just putting my heater on the windscreen and putting it on a switch so i could mount the cb where the controls are. I want to keep it looking standard now though. How come you've chopped more out? room for things to come?
- turbo-tom
Yeah the factory heater is still there but i have by passed it from the heater matrix (engine side)Ricky-410 wrote:I was thinking of just putting my heater on the windscreen and putting it on a switch so i could mount the cb where the controls are. I want to keep it looking standard now though. How come you've chopped more out? room for things to come?
so i only have the fan not really a heater any more
and yes more things! i have done them i just havent update my thread in long time
Tom
Ford Fiesta ST
Ford Fiesta ST
- turbo-tom
Well power steering jimny box, vitara radiator , twin electric fans, the answer? yes it can be done
The bottom of the fan is surported by two three mm thick brackets that have been welded into the back of my winch tray
This is the back of the the radiator and i havent had the trim the radiator ethier
And i fabed up some brackets for the top mounts These are bolted through the slam pannel
And then finally i modified the old expansion tank bottle and its bolted straigh the the passenger side wing
Tom
Ford Fiesta ST
Ford Fiesta ST
Colourful was the only word that sprang to mind.
I think that, if I ever finally manage to get mine roadworthy again, I'll have to swap in electric fans like those. Where'd you get 'em?
And did you ever paint those shocks???
:p
:p
